More on water pumps.
Ohio H
10-29-2003 09:25:55
Has anyone tried removing the impeller, shaft and pulleys from a farmall water pump. Seems that after doing this that the hole in the housing could be welded closed and the housing used as an intake fitting when using an electric pump. Just a theory..... H
REDMAN
10-30-2003 09:50:22
 Re: More on water pumps. in reply to Ohio H, 10-29-2003 09:25:55
i don't know what tractor model you are talking about,but on a 400 series diesel you can remove the pump and the housing.about 40 lbs total.
earlschieb
10-29-2003 14:46:03
Since I happen to have 2 H pumps laying on the bench, I will look into that thought.
