ChadS
Ohio H
10-27-2003 15:21:16
Chad you seem to be the "goto" guy for H's. I'm wanting to use an inline electric water pump. What is commonly used, and what do i do with the stock pump, leave it in place with belt removed or use a cover in the pump location. Any help appreciated..... H
TimC
10-27-2003 19:10:24
 Re: ChadS in reply to Ohio H, 10-27-2003 15:21:16
Mizorei (spelling) makes a good pump but needs the AN type fittings. Not the cheapest way to hook up. There is a pump brand of shogun that works.
Aluminum plate over water holes tapped with with water pipe fitting is simple and straight forward.
Hot water from head goes straight to the radiator and is suck thru to the WP and pushed into the block. Remove the factory WP to save weight.
The electric water pumps seem to flow a lot of volume so heater hose size rubber hose seems to work very well. Another option is to use a dc motor to run the stock pump for a little extra power to the wheels as long as you are not runing an alternator or generator.
ChadS
10-27-2003 15:37:23
This could be done in a number of ways. You could eliinate the stock pump, with a plate, with hookups to the elect, pump. the top hose would be the outlet, (hot) and the bottom hose would be the cold. The bottom hose could be hooked up to a elec. pump, to the bottom of the themostat housing. as long as you maintain the correct flow. I have never done this before, but have seen it done. Another way would be make the entire system a gravity flow. like the JDs As long as you have a hot water source into the cold water it will circulate. I don't know if I helped any but may give you an idea. ChadS
