NATPA Hitch rule Change; Oliver Setup??????
Jim F.
10-24-2003 05:11:47
Okay, as of 7-30-03, the top adjuster can no longer be above the center line of the axle on any tractor in any class. Now, what are the you Oliver guys doing to solve this? My hitch along with many others have the adjustable top-links that mount in the factory cast ears that the top brace off of the hitch bolted onto. Are you guys simply shortening the adjustable links and putting a strap to lower the mounting point of the adjusters at or below the centerline of axle? Thanks in advance.
Farmall Boy
10-24-2003 18:17:32
 Re: NATPA Hitch rule Change; Oliver Setup?????? in reply to Jim F., 10-24-2003 05:11:47
ACTUALLY thats only Div. 3 and up
Jim F.
10-27-2003 07:09:34
 Re: Re: NATPA Hitch rule Change; Oliver Setup????? in reply to Farmall Boy, 10-24-2003 18:17:32
You had better check those rules for Div II again... I just did and it reads that the top of adjuster cannot be above the centerline of the axle.
www.natpa.com
slowsmoke
10-25-2003 05:03:48
So Div I and II are OK?
Farmall Boy
10-25-2003 14:51:45
 Re: Re: Re: NATPA Hitch rule Change; Oliver Setup? in reply to slowsmoke, 10-25-2003 05:03:48
YUP here are the new rules for Div.1 through Div.4
GENERAL RULES All flywheels must be covered. All exhaust pipes must be straight up with no curves or bends.
Division I Drawbar must be 24 inches from center of axel to hitch point The wording, Exception: JD 30 Series allowed. Was added as per board meeting of 6/27/03.
Division II The wording, Exception: JD 30Seriws allowed. Was added as per board meeting of 6/27/03.
Division III, IV and V Rule #4 the wording, Top of hitch adjuster cannot be above center line of axle or hub.
YOU OTHER GUYS SHOULD HAVE DID A LIL BIT MORE HOMEWORK:p
slowsmoke
10-25-2003 16:55:17
 Re: Re: Re: Re: NATPA Hitch rule Change; Oliver Se in reply to Farmall Boy, 10-25-2003 14:51:45
I'm glad to see you did your homework, Thanks. Spelling 'series' can be a problem
FB
10-26-2003 08:29:22
 Re: Re: Re: Re: Re: NATPA Hitch rule Change; Olive in reply to slowsmoke, 10-25-2003 16:55:17
haha not for me...that was copied and pasted straight from natpa website so it was their mistake
slowsmoke
10-26-2003 10:58:36
 Re: Re: Re: Re: Re: Re: NATPA Hitch rule Change; O in reply to FB, 10-26-2003 08:29:22
mis-spelling something about a john deere is fine with me!!
oliver puller
10-24-2003 07:50:25
yes that is exactly what we are doing.
Jim F.
10-24-2003 08:26:51
 Re: Re: NATPA Hitch rule Change; Oliver Setup????? in reply to oliver puller, 10-24-2003 07:50:25
Interesting... so you are still pulling down on the same point but to satisfy the rules there is a strap installed to lower the top-link point of attachment to at or below the centerline of axle. Thanks.
oliver puller
10-24-2003 10:43:57
 Re: Re: Re: NATPA Hitch rule Change; Oliver Setup? in reply to Jim F., 10-24-2003 08:26:51
it is still pulling from the same place just the adjuster is lower don,t make sense to me.
FarmallHO
10-24-2003 11:40:09
 Re: Re: Re: Re: NATPA Hitch rule Change; Oliver Se in reply to oliver puller, 10-24-2003 10:43:57
If the lower bar breaks or comes loose it moves the pull point to the top attachment point. Instant stand up. Have seen it happen!!
