What is weight of unstyled JD B, a 1930's AC WC, or a WD?
Ken
09-18-2001 17:27:51
Does anyone know about the weight of unstyled, long hood, spoked or pressed steel wheels, no power-trol B? I was guessing around #2800.
How about a mid 30's Allis WC or a WD? Which would be a better puller, after a "few" engine mods?
Thanks.
KB
09-20-2001 07:29:23
 Re: What is weight of unstyled JD B, a 1930's AC WC, or a WD? in reply to Ken, 09-18-2001 17:27:51
Get the WC or WD. Not much comparison with a B. The B might have a chance below 3250 but definitely not above that. WC and WD's are cheap and are very competitive pullers, that is the way to go in the light classes. A JD A above 4000# can give them a battle with some work done.
agco puller
09-20-2001 06:22:59
The JD B with spoke cutoffs should weigh 3050 lbs
the unstyled WC with spoke cutoffs should weigh 2,950 lbs. and the WD should weigh 3300 lbs. You skipped the styled WC with cast wheels at 3050 lbs. I've never seen anybody with pressed wheels on a John Deere B(unstyled) but I'm sure somebody has done it. Isn't the power trol the hydraulic system first made available on the JD 60?
Power is easily made in the A-C's but that doesn't
always mean everything in the light classes and the guys watching are always routing for the John Deere's.
Ken
09-20-2001 11:38:53
 Re: Re: What is weight of unstyled JD B, a 1930's AC WC, or a WD? in reply to agco puller, 09-20-2001 06:22:59
Thanks alot agco for the info. I was just referring to tractor without the hydraulic system. Dad had 38" tires and may want to use the pressed wheels with them instead of cut-offs and 36" tires.
Greg H.
09-19-2001 06:42:02
Get the Allis, you'll get more out of it, although it might cost you more to build.
Flyin Farmall
09-18-2001 22:34:46
a WC will get in 3200,3500 no problems,a stock Allis will outpull a B everytime.it is easy to build a WC to pull,If your interested in one i'll sell ya one that's almost done real cheap!
Ken
09-19-2001 13:13:12
 Re: Re: What is weight of unstyled JD B, a 1930's AC WC, or a WD? in reply to Flyin Farmall, 09-18-2001 22:34:46
I'm checking this out for my Dad. Give me the info on the WC, $, where are you, etc and I will let Dad know. Thanks!
Leroy
09-18-2001 20:07:56
My 37 B with cut offs and 36inch tires weights right at 3000 pounds.
Ken
09-19-2001 13:15:06
 Re: Re: What is weight of unstyled JD B, a 1930's AC WC, or a WD? in reply to Leroy , 09-18-2001 20:07:56
Hey thanks Leroy for the info. I wasn't far off at #2800. How does yours pull?
Leroy
09-19-2001 15:46:41
 Re: Re: Re: What is weight of unstyled JD B, a 1930's AC WC, or a WD? in reply to Ken, 09-19-2001 13:15:06
Pulled it twice got first and second.with my girlfriend pulling it.
