NEED PISTONS
JIM
10-22-2003 13:50:25
NEED PISTONS FOR A 7 INCH JD G BLOCK ANY HELP WOULD BE GREAT THANKS JIM
Rick
10-22-2003 17:27:14
 Re: NEED PISTONS in reply to JIM, 10-22-2003 13:50:25
i sell pistons but i can also put the wrist pin in the location that you want and if you get to close you can shave a little of the top of piston
JIM
10-23-2003 07:41:04
 Re: Re: NEED PISTONS in reply to Rick, 10-22-2003 17:27:14
U GOT 7 IHCH ONES FOR A JD G THAT ARE DOMED AND ARE5 INCHS TO THE TOP OF THE DOME THANKS JIM
rick
10-23-2003 14:21:14
 Re: Re: Re: NEED PISTONS in reply to JIM, 10-23-2003 07:41:04
pistons cost 1130.00 with rings i can put wrist pin where you like and cut ring groves where need if i have to send them by mail back and forth the cost will go up but is recomended for stroker before cuting wristpin hole and rear ring grooves
N Puller
10-22-2003 20:45:03
do you sell 8n ford pistons with the high compresson dome on one side next to the valves?
if not would you know who has them?thanks n puller
Rick
10-23-2003 10:26:01
 Re: Re: Re: NEED PISTONS in reply to N Puller, 10-22-2003 20:45:03
i can have them made to 7 in and bore wrist pin to the 5 in center height number is 724 894 2982 for the ford i sell a complete engine kit for the 8n with dome pistons but i will warn you that sometimes they hit head and that you might have to replace it
Earl S.
10-22-2003 21:40:37
What bore do yo need and what comp distance??
