What is torque??
N-line 4
10-22-2003 13:26:18
What would yall define torque as and how do you
build it...Anbody know a website to find torque
numbers for these old tractors??
G-MAN
10-22-2003 14:00:06
 Re: What is torque?? in reply to N-line 4, 10-22-2003 13:26:18
Torque is defined as a twisting or turning force. Shaft rotation need not be present to measure torque. Horsepower is a function OF torque (HP = (Torque x RPM)/5252, so torque and horsepower are always equal at 5252 rpm. Shaft rotation does have to be present to measure horsepower. Increasing torque also increases horsepower. When it comes to building torque, anything that increases how much harder you can twist the crankshaft will increase it. Longer strokes provide more leverage in relation to the crankshaft centerline, which increases torque. Bigger bores increase the surface area of the piston that is acted on by cylinder pressure, which increases torque. Increasing the cylinder pressure by forced induction or raising the compression ratio also increases the force on the piston, which increases torque. It's not rocket science - just simple physics. Anything you can do to make that piston push down farther, or make the crank arm longer, will increase torque.
