More hp for an H
M Puller Too
10-21-2003 16:11:58
I have a stock 1942 H that I rebuilt 4 years ago. I put super H fire crater pistons in it but other than that, it is pure stock. I didn't touch the head. It has a distillate head and manifold. I'm looking to make a puller out of it for my girlfriend, and was wanting to get some opinions on some modifications. I'm not looking to stroke it. How much horsepower can I expect without stroking. 40 hp seems reasonable. Thanks.
h puller
10-21-2003 18:04:45
 Re: More hp for an H in reply to M Puller Too, 10-21-2003 16:11:58
You can get 40hp in a H by boring the block and use farmall 350 pistons. I got just over 40hp with this set up with a gas head. I put on a lp head and I was close to 50 hp.
41FARMALL
01-30-2004 14:44:17
 Re: Re: More hp for an H in reply to h puller, 10-21-2003 18:04:45
HAVE H FARMALL WITH 3 9/16 PISTONS 300 GAS HEAD SHAVED SUPER H MANIFOLD LOW-LOW 1ST GEAR HOW MUCH HP DO I HAVE CAN PULL IN 5500 CLASS IN FARM STOCK AND STILL HAVE POWER
ChadS
10-21-2003 23:00:12
40 hp is ok,,, if you use different head you could see up to 45 to 50hp. use the big manifold and carb ChadS
Hank
10-22-2003 06:17:54
 Re: Re: Re: More hp for an H in reply to ChadS, 10-21-2003 23:00:12
what is the big manifold you are refering to.I wasent aware there are different sizes just designs.
Chads
10-22-2003 18:17:57
 Re: Re: Re: Re: More hp for an H in reply to Hank, 10-22-2003 06:17:54
There is 4 different manifolds for the H-350 gas tractors. Distillant, gas, all fuel, and lp. The SH-350 uses the bigger carbs,, like the M. The lp manifold is the best for air flow. It is also a 2 piece unit. 2 different carb mounts one for the small carb, and one for the big carb.. hope this helps chads
