Are all dynos equal?
mta puller
10-21-2003 13:14:18
Does anybody have any experience on how different dyno's read hp, some show a higher # than others, and how about the ones that convert torque to hp and so on, m-w vs newer dynos?
Jim F.
10-22-2003 06:42:43
 Re: Are all dynos equal? in reply to mta puller, 10-21-2003 13:14:18
Myself and a few buddies have joint ownership in a M&W dyno. This machine was well taken care of and when we purchased last year we went all through it. New oil, tach cable, flushing everything out. I feel it is a good machine. A few tractors we have checked have read within a few HP (1-2) of other dynos, one being a local club dyno and another in Ohio. Now alot of different variables here, altitude, air quality, was the dyno properly warmed up? A cool dyno will read more HP, etc. But referring to the original question asked, I would say yes they should read fairly equal results. Hope this helps resolve any issues.
vjohnyboy
10-21-2003 16:27:25
most dynos are close in horse and and if calibrated they should be real close now a m&w hydraulic will only reed at rated rpms but the one we use at our shop is a A&W it is digital and seems to be very accurate we calibrate it often and have had complements on it but it reads foot lbs horse and torque rise
G-MAN
10-21-2003 14:02:02
Comparing different brands and vintages of dynos is like comparing apples and oranges. And any dyno is only as accurate as the operator. In my opinion, you're best off to use the same dyno and the same operator for every test, if you are using to check performance gains. Otherwise there is no way to get consistent results. Even if the dyno is older and is off by 5%, it should at least be off by 5% time and again, which will probably produce more accurate results than using dyno X one time and dyno Y the next. Any shop that uses their dyno a bunch, should be making sure that it's kept fairly accurate. But, a lot of implement dealerships and other shops don't get that into accuracy, because they use the dyno as a diagnostic tool, not a precision measuring instrument. Being 5 hp off on a 200 hp tractor isn't a big deal, but 5 hp off on a 40 hp tractor is.
exactly
10-21-2003 14:50:47
 Re: Re: Are all dynos equal? in reply to G-MAN, 10-21-2003 14:02:02
I've seen dynos read 15 hp difference on the same tractor with no changes between runs.
