253 GM
Bill
10-18-2003 20:10:44
Looking for a little more power from a 253 detroit 45 at present would like another 10. have a 18.3 to 1 and a 21 to 1 both about the same power. Any ideas with out going extremes. Pull in the 4000 lb. class
buickanddeere
10-20-2003 20:32:44
 Re: 253 GM in reply to Bill , 10-18-2003 20:10:44
N60's are about the point of peak power for the natural aspirated 2-53 two valve per cylinder. They will make smoke and start questions about being stock or not. 21 to 1 will make more power than the 19 to 1 turbo pistons or the 17 to 1 "S" pistons. 2400 rpm is fine with the late HP cam follower springs and valve springs. 60HP at 2400rpm and N45's is normal. More airflow from a dry airfilter conversion helps. The stock clutch may slip unless a new spring is installed. I also had a high friction compound disk made with more surface area too. A bit jumpy on the clutch until gotten used to. Oil cooling for the pistons will be required with N40 or larger injectors. I would like to slow mine in each gear 30% with the pre 31,000 model 1010 ring and pinion along with the post 31,000 model 1010 final drive gears.
Willy Murphy
09-21-2005 05:26:22
 Re: Re: 253 GM in reply to buickanddeere, 10-20-2003 20:32:44
I know your not Talking about the 3-53 but thought i"d ask..I have a 3-53 with S45 injectors. can anyone explain the differance"s
in the injectors. can i replace the S45 with
N45"s without other problems? Is the "S" just lower compresstion Pistons? N45 are not as hard to find as the S45"s.
Thanks for any advice..
