Cockshutt 40
Jerry
10-17-2003 16:37:40
I am replacing the motor in a Cockshutt 40 with a 262 Buda and the flywheel and the clutch parts all fit from the 40 but one ear on the pressure plate is about 1/8 inch higher than the other three when it touch,s off at the throwout bearing. I am afraid that it might cause me problems. I might pull this one and I have heard of ceramic clutches but don't know of a source to purchase one and what effect it would require of my flywheel. Any help would be very helpful.
max puller
11-02-2003 08:54:25
 Re: Cockshutt 40 in reply to Jerry, 10-17-2003 16:37:40
Thought we were never going to pull it just a collectors tractor?
Dave N
10-19-2003 14:17:55
Sounds like you need to adjust the pressure plate adjust the finger tht is a different height there is normally a nut that is staked just turn that nut to raise or lower the finger.It could cause your clutch to drag if out of adjustment. Dave
