mm.heads
ken
10-17-2003 10:06:18
I am thinking about buying a mm ULP , the block # is 15154 and the heads are 4207 is this a good combination for pulling. Thanks for your help...Ken
Mopower
10-20-2003 10:08:41
 Re: mm.heads in reply to ken, 10-17-2003 10:06:18
Ken,
If this is a stock size motor, the compression should be ideal for LP and maybe higher octane gas. I think the chart says this is about a 9.5 to 1 compression ratio with 4207 heads. It would make a good stock puller, that's for sure. Maybe even better if you opened that bore up a little. Not sure, but always wondered about the 4207s. How does it run? Always a fan of LP gas machines. I never had one of my own. Just gas and diesel.
Ethan
