SOUTHERN NATIONAL RULES TUNICA, MISSISSIPPI December 5 & 6Mean Green Pulling Team and Fitzgerald�s Casino Farm Stock II Classes Pre-1960 Tractors with stock engine... No cut tires... 18.4 X 38 Maximum size... Hang on weights permitted... 10% over stock RPM allowed... Wheelie bars are mandatory... 1st. Gear only. 4mph maximum. 4 MPH & 8 MPH Classes (modified) Pre-1960 Tractors with internal engine modifications...Spacer plates, girdles, power blocks, 12 port heads...800 heads and jugs are allowed... All parts must be on tractor origin...18.4 X 38 max. tire size...any cut, any rim width...no duals...Weights: 11' from center of rear axle to furthest point of front weights...Rear weights must not extend beyond rear tires...20% over stock RPM...Any gear, 4 MPH Max and 8 MPH Max...20" draw bar height, 18" back from rear axle...Wheelie bars & breakaway switches are mandatory...No alcohol, no nitrous, no turbos, no blowers. No Speed Limit Classes Same as above except 30% over stock RPM is allowed. Speed limits begin when any part of a tractor passes the orange cone at � track. Tractors with side shields may be inspected prior to pull.....If a protest is made, it must be made before the end of the class. Protestors tractor will be examined first. Then and only then will the protested tractor be checked. PULLING ORDER (Only 3 pulls per tractor for 2 days) FRIDAY SATURDAY Farm Stock II Modified Modified Modified (Green Sled) (White Sled) (Green Sled) (White Sled) 4500# 4 mph 6200# No limit JD King of the Hill All other King of the Hill 5500# 4 mph 7200# No limit 3500# 4 mph 6500# 8 mph 6500# 4 mph 7500# 4 mph 3500# 8 mph 6500# 4 mph 7500# 4 mph 7500# 8 mph 4200# No limit 5500# No limit 10,000# 4 mph 4500# 4 mph 5200# No limit 4500# 8 mph 5500# 8 mph Have fun and keep in mind this is not a political event or debate!!
