Big pistons for a Super M
Wide Front SM P
10-16-2003 08:39:44
Does anyone know where I can get a set of 4 5/8" or 4 3/4" pistons for my super M?
randy hall
10-16-2003 12:43:51
 Re: Big pistons for a Super M in reply to Wide Front SM Puller, 10-16-2003 08:39:44
i have a set of 4.625 pistons. what compression distance do you need?
10-16-2003 14:18:28
 Re: Re: Big pistons for a Super M in reply to randy hall, 10-16-2003 12:43:51
I will have to confer with a few people who know alot more than I do, what are you asking for them?
randy hall
10-17-2003 12:56:47
 Re: Re: Re: Big pistons for a Super M in reply to Wide Front SM Puller, 10-16-2003 14:18:28
i would like $150 for the pistons and the rings that came with them and if you were interested i have a set of total seal rings for these pistons.
TimC
10-16-2003 10:38:59
You can see a picture of what J-E did on a 4.750 bore piston in the parts and pieces. Delivery time was around 2 weeks.
IH 4130- Connecting Rod. These are domed but flat top would probably be cheaper.
Flogger
10-16-2003 09:50:20
Check with Ross and JE's and see what you can get a set made for. They're not inexpensive but the quality is first rate and they can usually deliver in a couple weeks.
tjstoy
10-17-2003 06:03:35
 Re: Re: Big pistons for a Super M in reply to Flogger, 10-16-2003 09:50:20
How do you guys get 4.75" pistons in an M??? I was told when I bored mine to 4 1/8 that it was as big as I could go without boring through the cylinders. Is this not so or do you just run the pistons in the sleeves letting the top of the cylinder hold them??? Confused and Curious
Flogger
10-17-2003 08:37:20
 Re: Re: Re: Big pistons for a Super M in reply to tjstoy, 10-17-2003 06:03:35
I think for the really big bore sizes they move the bore center over to the right side of the block, bore through the original cylinder and press in a custom sleeve to seal everything off. From what I've been told the block has to be re-enforced because boring it that big weakens it.
jake
10-16-2003 18:18:36
thats nothing my super M runs at about 5 inches and has a 5 and a half inch stroke iam runin at about 600 cubes.
TimC
10-16-2003 18:42:06
 Re: Re: Re: Big pistons for a Super M in reply to jake, 10-16-2003 18:18:36
He is talking about a 4 cyl. You gotta have 6 to get 600 outta yours or your calculator is messed up. 5 X 5 X 5.5 X .7854 = 432.
Lloyd Powell
10-16-2003 18:33:54
Flogger please e-mail me at [email protected] I would like to talk to you about larger bore to my 53 SM. I am looking for a little more power. I have installed an elec. ig and am now having a new clutch and pres plate installed. I will use it for farm use now but later who knows. would a 4.50 bore make it run hot plowing?
supermpuller4
10-16-2003 19:17:43
 Re: Re: Re: Re: Big pistons for a Super M in reply to Lloyd Powell, 10-16-2003 18:33:54
I would not be afraid to plow with a 4.25 bore and 6.5 stroke but thats as big as I would go if I wanted to farm some.
Farmaller
10-17-2003 13:22:35
 Re: Re: Re: Re: Re: Big pistons for a Super M in reply to supermpuller4, 10-16-2003 19:17:43
What kind of horsepower are we talking about with this set-up?
supermpuller4
10-17-2003 18:33:00
 Re: Re: Re: Re: Re: Re: Big pistons for a Super M in reply to Farmaller, 10-17-2003 13:22:35
4.25 by 6.5 should be a little over 100hp depending on what kind of head your running.
Flogger
10-18-2003 08:22:02
 Re: Re: Re: Re: Re: Re: Re: Big pistons for a Supe in reply to supermpuller4, 10-17-2003 18:33:00
Hey smpuller,
What rod and piston would you be running with this set-up, and does the stock head gasket work okay?
