? On Rim Sizes
BD
10-16-2003 08:38:31
I am putting a set of 14.9X38 tires on my 38 G, and the NATPA rules say go with the rim size stated on the tire. It calls for a 13" rim which is not available around here. Am wanting to know what others are running. Is it acceptable to mount on 14", or am I going to have to drop to a 12"? Are there any 13" rims to be had?
Mike Aylward
10-16-2003 20:24:31
 Re: ? On Rim Sizes in reply to BD, 10-16-2003 08:38:31
BD, there are 13" rims around but they are not too common (about as common as 14.9's). The 14" rims will work very well and are probably the most common size used with 14.9's. A common fix would be to find a narrower rim and widen it to the size you need. But a 12" rim will get you by. Hope this helps. Mike
IH H Puller
10-17-2003 14:48:17
 Re: Re: ? On Rim Sizes in reply to Mike Aylward, 10-16-2003 20:24:31
I run a set of 14.9x38 cuts on 14 in. rims and am very pleased with the results. It widens them just enough to get that little extra tread on the ground.
