MM jugs
Family Traditio
10-16-2003 08:02:40
what is the largest bore, short jug available for MM?
Mopower
10-16-2003 09:03:20
 Re: MM jugs in reply to Family Tradition, 10-16-2003 08:02:40
My two cents:
M5-M670 were 4-5/8 jugs, however I belive if you go with diesel jugs, they are thicker and have a little more room to bore. Don't take my word for it, but you might be able to get 4-7/8 out of them. I have diesel M5 blocks sleeved at 4-3/4 right now with old M&W pistons to try out. If that is not big enough, I would suggest contacting Doug Henderson. He builds so pretty big bore short blocks. There is also a place that makes solid cast iron short blocks with huge bores. I have not heard much feedback on those yet. Let me know if you want names and numbers or info. I don't build anything wild or pull an aweful lot, but I do keep my ears open in the MM pulling world.
Ethan
