rear wheels
Mark H.
10-15-2003 13:45:07
Afternoon, I just bought 2 12x38 rims and centers not welded together yet, Question is where would be the best place to weld the centers. Would dead center be right or do I want some offset. These will be going on a semi stock MM Za pulling in the 4500lb class, Thanks Mark H.
Red
10-16-2003 07:29:21
 Re: rear wheels in reply to Mark H., 10-15-2003 13:45:07
About the rear wheels. I would go with dead center. When a center is welded offset you have the chance to get a rim buckling effect when the tires are loaded down and they spin out. You obviously cant see the rim buckle but the bind that is put on the wide side stresses the rim. Everything should be in a straight line for max strength. like an I beam so that the force is dispersed evenly through the rim. Good luck
