Turbo/fuel for IH 1466
John
10-15-2003 04:41:04
Hi Folks:
I came across a 3lm turbo for an IH setup that has one run on it, what is it worth? With this turbo on a 1466, what fueling mods will I need to do to it to make it run good and what is the most power I can get out of it? It was my understanding that a 3lm was good for 300-400 horse relatively easily. What can a new one be bought for?
Is it easier to have a rotary pump re-worked or just adapt a inline Bosch pump?
Thanks a million!
John
REDMAN
10-16-2003 19:55:12
 Re: Turbo/fuel for IH 1466 in reply to John, 10-15-2003 04:41:04
i don't think it is worth 400,go with the in line they produce more fuel with less trouble.to bolt the in line on you need to go to a international truck dealer and get the fuel pump adapter from a truck engine and the drive gear.if you check some of the tractor pulling boards like fullpull.com you should be able to find a pump for around $2000.a rain cap is still a legal air kill for most brush pulls and really all you need for a 3lm,if you go bigger call stabb machine in wisconsin and they will set you up with a nice air kill.
John
10-17-2003 04:56:55
 Re: Re: Turbo/fuel for IH 1466 in reply to REDMAN, 10-16-2003 19:55:12
RedMan, they are wanting 400 for the 3lm turbocharger. I'm wanting to buy a 1466 this winter and start pulling in the spring. I will probably pull in the 9000-14000 # classes. There is quite a bit of competition. I don't know whether to modify right off of the bat to an inline pump or re-work the rotart. Which rotary pump do these engines run? Are they a roosa master like what the Deere's use?
Thanks!
John
Pete1468
10-18-2003 12:13:01
 Re: Re: Re: Turbo/fuel for IH 1466 in reply to John, 10-17-2003 04:56:55
I've got a factory inline setup for a IH if you are interested, has the intercooler lines, front drive gear, adapter plate, and pump. e-mail me if interested. Thanks
Pete1468
10-15-2003 17:37:49
Is it a stock 3lm turbo or does it have the bigger wheel installed in it? Your fuel pump is it turned up or is it stock, what class are you going to run in? 3lm's are a very good turbo, even in stock situations they will build more boost than a air research.
jason
10-15-2003 18:00:59
 Re: Re: Turbo/fuel for IH 1466 in reply to Pete1468, 10-15-2003 17:37:49
I pull a 1466 also,with a holset charger 17mm pump. for you crank the fuel screw and remove the fuel stop block under the cover. Make sure you have an air kill or fuel shut off though for safety. you will make about 350hp. your clutch is only good for about 250hp so you will be replacing that after a dozen hooks or so with a two disk clutch.
REDMAN
10-16-2003 19:48:34
 Re: Re: Re: Turbo/fuel for IH 1466 in reply to jason, 10-15-2003 18:00:59
a 17mm pump???where on earth did you find one of these?last i checked 15mm was as big as they get.
John
10-16-2003 04:55:49
What exactly is the fuel shutoff/air kill? I have seen one type of air shutoff, can you buy them for a decent price or do you make them? You are saying that 350 horsepower can be made with the stock pump?
I don't have an IH yet. I came across a 3lm turbo (I believe it's stock) with 1 run on it for $400. BTW, Will a 3lm off of a 1066 bolt right on the manifold of a 1466? Any more tricks you can tell me the better, keep the good words coming.
John
Jason
10-16-2003 06:03:34
 Re: Re: Re: Re: Turbo/fuel for IH 1466 in reply to John, 10-16-2003 04:55:49
In all open farm classes you must run an "airkill" which can be activated by the driver or sled. The fuel shut off is simply a valve on the line between the filters and the head of the pump so officials can run up and shut it down. I have buit a dozen airkills for people and have what i think is a flawless design. I sell it for $60 but i can send you a picture so maybe you can build your own.I am going to be in the fields for a few days so email me with your address.
