Where are you now BY STANDER
Hillybilly Hook
10-14-2003 20:20:24
I guess you havent got the nerve to get back on here and talk crap huh? H.H. yellar tractor
bystander
10-15-2003 19:46:51
 Re: Where are you now BY STANDER in reply to Hillybilly Hooker, 10-14-2003 20:20:24
There is no reason for you to get beside yourself. I saw how the scales were working. I watched a JD on the scales moving back and forth and there was about 400 differance one end to the other.
Banet Enterprises
10-15-2003 23:14:22
 Re: Re: Where are you now BY STANDER in reply to bystander, 10-15-2003 19:46:51
The scale problem could easly be corrected on most scales by having a scale company calabrate the corners. The varence is a common problem which usually only requires a resistor in one of the wires to the load cells. Even if you buy 4 weight cells with the same serial, part & wt. load numbers, they may weigh the total wt. correctly, but if one cell has just a small amount of power more than the others, the ends will not weigh equal. Thus, moving forward or back could change the overall wt. Just by walking the 4 corners & checking your wt. at each one, then stand in the middle & do the same, you can usually tell which cell needs attention. We have fixed the problem temporaly with resistors from radio shack. Normaly when we have this problem, we take our scale to our local scale company & set it up in the parking lot. This saves paying a service call. The good news is it doesn't cost a arm & a leg. Banet Enterprises, John sr, Kevin, John Banet. Hope this helps!
Hillbilly Hooker
10-15-2003 20:13:14
Well dont be posting B.S. about my weight not being legal. I know within a few pounds what my tractor weighs. It weighs 6050lb with me on it. In 6500 I had 4 90lb weights. And in 7500 I had 14 so do the math. H.H.
ARKANSAS
10-15-2003 20:28:23
 Re: Re: Re: Where are you now BY STANDER in reply to Hillbilly Hooker, 10-15-2003 20:13:14
Which bystander brought out your ill temper?
Hillbilly Hooker
10-15-2003 21:17:26
 Re: Re: Re: Re: Where are you now BY STANDER in reply to ARKANSAS, 10-15-2003 20:28:23
The one who put a post on here a few days ago that said that I cheated on weights at Bernie Mo. I didnt mean to come across iLL tempered, it just aggitated me that he falsley acused me. Sorry for the tantrum. H.H.
AKBEATER
10-15-2003 03:13:57
DO YOU THINK THIS (BIE SLANDER) pulls a 460 turbo maybe???
Hillybilly Hooker
10-15-2003 20:14:46
 Re: Re: Where are you now BY STANDER in reply to AKBEATER, 10-15-2003 03:13:57
MAYBEEEE
