Ohio M puller?????
HMMMMMMMMMMM......
10-10-2003 15:13:47
I know that with the 4020 LP pistons you use a 6 1/8 stroke. Is their alot of grinding required in the block? What kind of compression are these running with gas heads. How much horsepower can you expect? Will a stock carb feed it?And what do you expect it would cost to put it together?/
Ohio M Puller
10-11-2003 16:56:49
 Re: Ohio M puller????? in reply to HMMMMMMMMMMM......, 10-10-2003 15:13:47
Well grinding is very minimual yet it will require some but you won't have to touch the cam. We ran a 400 gas head so I am not sure about a M gas head however we were at 10.25 to 1 and dynoed right at 85 to 90 horse all in altitude berrometer reading and each days temperture. As well we put in a 450 gas cam that seemed to help. The carb put in a 806 bowl and venturie, as well drilled out the fuel jet a little. You will be looking at around $2000 to $2500 for completion. Good luck and are you wanting to run Div 2 with this motor? If so you will do very well compared to most.
Ohio M Puller
bill
10-13-2003 10:10:45
 Re: Re: Ohio M puller????? in reply to Ohio M Puller, 10-11-2003 16:56:49
OHIO M PULLER. SUNDAY AT HILGERS, 10-19-03 45-55-6500 # CLASSES 30 PERCENT RPM LIKE DEFIANCE. STARTS AT 9 A.M. TAKE 30 WEST OUT OF FORT WAYNE ABOUT 6 MILE ON YOUR RIGHT. IN. 450 PULLER.
Ohio M Puller
10-13-2003 12:13:20
 Re: Re: Re: Ohio M puller????? in reply to bill, 10-13-2003 10:10:45
Bill,
Thanks for the invite but the Black M is torn down for this year. Time for yearly maintnance (sp), bearings, oil, rings, and ect. As well I am headed to Virginia Beach for a buddies wedding I am in so I have to say sorry and allow you to represent the farmall name for us at Hilger. Maybe next year.
Ohio M Puller
