Rod stretchin
XXX
10-10-2003 09:26:08
I'm preping my '38 A for stroke change, makeing my own rods is evident. I would like to build my own jig, cut, lengthen and reweld the rods my self. Please share your experiences good or bad.
TimC
10-11-2003 19:16:31
 Re: Rod stretchin in reply to XXX, 10-10-2003 09:26:08
Since you only need two rods avoid welding unless you are positive you can't find a way to have some made in a price range you can afford. There is someone on this board with access to a waterjet that could cut you a nice set of rods cheap then all you would need to do is have a machine shop cut the rod bolts and split the cap. Any machine shop could size them to fit your bearings.
ChadS
10-12-2003 00:00:32
 Re: Re: Rod stretchin in reply to TimC, 10-11-2003 19:16:31
I can do that. let me know if you are interested
