Need help building a 48 John Deere pullin engine
Matt
10-09-2003 14:36:16
I want to know what I should do to get some horsepower out of my engine. One well known person told me that he could bore it out to 5 3/4 and stroke it to 9" and with some other work would get me good horsepower. I am a little scared of this. But any information and Ideas would really be appreicated. Also if any one knows of a good machine shop near Virginia would be great also.
chuck
10-13-2003 20:12:47
 Re: Need help building a 48 John Deere pullin engi in reply to Matt, 10-09-2003 14:36:16
Matt, I have an 8" crank for sale, used very little, let me know. Chuck.
jdk
10-10-2003 09:06:37
All I can tell you Matt is that I have been running the same setup you are proposing for almost 10 years and have been very happy. With some hard work and time well spent, you will have a very reliable and competitive tractor.
buickanddeere
10-10-2003 07:37:33
The biggest HP restriction are the heads/intake system designed to make torque at low rpm on lantern fuel. They used long, small dia heated passages with a huge eyebrow in the combustion chamber to induce turbulance. A Heiser aftermarket head or having a pro install larger intake valves and port the areas an inch upstream and down stream of the valve seat. Install nail head valves too. Hogging a port out huge, way back from the valve look great but gain nothing. A cam with extra lift, some compression, low restriction intake filter, exhaust and away you go with stock bore and stroke. If the engine is breathing through a straw, bigger lungs can only "pull" a little more air. Of course all the HP in the world just throws dirt at mid track. Then get beat by someone else with a stock engine makeing a full pull with good tires/balance.
Hillbilly Hooker
10-09-2003 20:24:22
My advise would be sell the JD to a collector and get yourself a good M Farmall or a Moline. H.H.
Mopower
10-10-2003 11:23:12
 Re: Re: Need help building a 48 John Deere pullin in reply to Hillbilly Hooker, 10-09-2003 20:24:22
Agreed. MM can b-r-e-a-t-h-e with the big old heads. It is nice to see a JD built and tuned correctly for it's cubes. Just from observation, I think it is harder to balance a Deere. MM seems to have a good balance without much work in the right classes. That is from experience. Although a JD H competes well in 2500 if only a few more ponies could be cranked out.
matt
10-10-2003 04:42:04
That is exactly why I am building the tractor. I get so tired of seeing the same red tractors win at some of the pulls. But they always have a problem when a JD with a good engine beats the crap out of them on the track.
Jeff
10-11-2003 22:30:51
 Re: Re: Re: Need help building a 48 John Deere pul in reply to matt, 10-10-2003 04:42:04
have you thought of going to an Oliver? I have an 88 that is doing really good against the red and other green ones. Of course i am pulling farm stock and as faras I know mine is stock as it come off of a farm and all I have done is changed the wheels to pressed steel, added wheelie bars and made a hitch 20 inchs high and 18 from the axle. heck I had the hitch 18 inches high and when I moved it the extra 2 inches it made 30 ft difference. Moline's make real good pullers also but Olivers are more available around here and Jd's and farmalls are a dime a dozen.
a puller
10-09-2003 17:33:38
bore it to 5.75 and stroke it 8" and you will have 75 horse and can still run a few rpm.
Matt
10-10-2003 04:43:44
 Re: Re: Need help building a 48 John Deere pullin in reply to a puller, 10-09-2003 17:33:38
A puller, can you give me a little more info or even e-mail me direct and we can talk about the set up a little more. thanks
