Need directions to Bluffton IN pull
Farmall Daddy
10-08-2003 12:37:36
Where will the pull be at? What time? Also, what kind of rules to they have? Thanks in advance!!
kevin banet
10-08-2003 18:53:51
 Re: Need directions to Bluffton IN pull in reply to Farmall Daddy, 10-08-2003 12:37:36
It's on us1 at the south end of Bluffton IN.. at the wells county fair grounds .It's a div.2 pull they run 2 tracks one with div2 one with div.3.they run 3000/3500;4500;5500;6500;7500;8500;10000.All div 2 try will use our scale and terminator sled plus john brooks tps sled on div.3 track.Hook fees will be i believe $7.00 .in div.2.It's always a power track.Weigh in 8:00, pull time 9:00.The wheels guys always do great job .Hope to see all you their.
sos puller
10-09-2003 11:53:03
 Re: Re: Need directions to Bluffton IN pull in reply to kevin banet, 10-08-2003 18:53:51
what are hook fees and pay back for div 3 thanks
StevenJ
10-09-2003 10:13:08
Bluffton is a power track my left foot. A completly stock tractor can go out there and run 2nd gear. It takes absolutely no power whatsoever. If you wanted a power track go out to john brooks pull and then see what a power track is. Slow MOOOO . DDDrrrr
slow mo57
10-10-2003 23:20:45
 Re: Re: Re: Need directions to Bluffton IN pull in reply to StevenJ, 10-09-2003 10:13:08
I like John Brooks but I pulled in 2gear there to last year & won 1&2 in 4500 1&3 in the 5000 and also a 4th 6500.Bluffton does have good power tracks to most people would say.They both build good tracks.
Farmall Daddy
10-08-2003 19:23:38
Thanks Kevin. Plan on being there saturday.
k.b'
10-10-2003 00:04:52
 Re: Re: Re: Need directions to Bluffton IN pull in reply to Farmall Daddy, 10-08-2003 19:23:38
yes. john has been wrenching on both the 600&his 445 and he's got them both sounding good i hope they stay that way.thank god for him.
KEVIN B.
10-08-2003 19:45:09
ARE YOU ALSO GOING TO P.HEIGHTS? WHAT TRACTORS ARE YOU BRINGING?
Dick L
10-09-2003 17:44:01
 Re: Re: Re: Re: Need directions to Bluffton IN pul in reply to KEVIN B., 10-08-2003 19:45:09
Can I come and pull, Huh, Can I?
Farmall Daddy
10-09-2003 07:38:33
I plan to make it up there too. Not for sure, but the WC will be there, most likely the M, and planning on getting the Oliver out. Might bring the 560 down to Hilger's. Not for sure though. See ya then! Did you ever get the Moline going?
slow mo57
10-09-2003 20:43:32
 Re: Re: Re: Re: Re: Need directions to Bluffton IN in reply to Farmall Daddy, 10-09-2003 07:38:33
YES, maybe I will see on sat.
