Hiesler head
JD Puller
10-07-2003 19:36:35
what is the difence in a hiesler head and a stock head for a John Deere?
jons
10-24-2003 20:53:32
 Re: Hiesler head in reply to JD Puller, 10-07-2003 19:36:35
the unstyled g head was a flat head. but if you are using high compression pistons you need to have the head reinforced. i talked to a local machine shop and they put dowels in the head to reinforce the flat spots in the compression area.
a puller
10-09-2003 17:45:29
I believe you can get a regular head to out perform it. the swirl helps with power too..and the heisler doesn't have the swirl.
farmer
10-08-2003 00:23:57
a stock JD head is low compression, the hiesler head is high comp. and has bigger valves.
jd puller
10-08-2003 11:28:21
 Re: Re: Hiesler head in reply to farmer, 10-08-2003 00:23:57
I relize that but how did they raise the compression is there a block cast into the head that sets into the cyliders or what.
G-MAN
10-08-2003 15:40:36
 Re: Re: Re: Hiesler head in reply to jd puller, 10-08-2003 11:28:21
I believe they're a "flat" head, meaning that the fire-deck surface is completely flat, with no cast-in combustion chamber. I think they're similar to the heads on the unstyled tractors, which were commonly installed on the styled tractors to boost compression without swapping out the pistons. If you're familiar with the "G", the unstyled "G"s had a cylinder block with an inch longer bore than the "GM" and styled "G". The stroke was the same, but the longer bore of the unstyled block offset the lack of a combustion chamber in the flat head. Installing a flat head on a styled tractor gives you the added compression of a flat head AND a shorter bore. The larger valves would improve air-flow slightly, as well.
rusty (superbee) - Facts
10-08-2003 22:07:30
 Re: Re: Re: Re: Hiesler head in reply to G-MAN, 10-08-2003 15:40:36
jdpuller, if you want to know email me. We have several Hieslers in house if your interested, I give you the facts and not maybes and I heards.
Rusty
G-MAN
10-09-2003 15:53:44
 Re: Re: Re: Re: Re: Hiesler head in reply to rusty (superbee) - Facts, 10-08-2003 22:07:30
So were my "maybes" and "I heards" right or wrong? You see, unless I know something for an absolute fact, I don't present it as one. But, like I posted, I "believe" I'm right. So tell me if I am or not. If I hear it from an expert like yourself, next time I'll KNOW the answer for a FACT and will post as such.
10-09-2003 17:38:03
 Re: Re: Re: Re: Re: Re: Hiesler head in reply to G-MAN, 10-09-2003 15:53:44
yes....some are flat with compression rlease hollow spot that looked like a triangle kind of...:S, and the unstyleds had a raise to them.
