Mike F
10-07-2003 19:45:08
Re: Re: Re: Re: flipping tractors in reply to Jerry, 10-07-2003 16:14:31
The rod and chain idea may work and I know our club has thought about it, but nobody wanted somthing hooked to their tractor, I think it is a matter of time, if you pull, you have wheely bars and I agree, I have seen some very seasoned pullers, nearly flip and they knew how to run their stuff, but for the novice, it could be his last pull, A chain will not stop a tractor from flipping and if it is that high, you are likely already in panic mode, which could mean hitting the wrong pedal or slamming the front end to the ground and really bust the thing up, guys will spend 500 bucks or more for a stack of weights to go and pull, but no safety gear, if they told us we had to have them in the stock class, I would go get the steel in the morning, and they can be made to be removed quickly, so what is the big deal? Sure isn't worth getting killed or injured bad enough to watch from a wheelchair. Remember never say never, because that is when it will happen. All these clubs had better get safety in order 1st and worry about who is gonna buy the trophy's later, get a good bunch of guys who can and will tech check all tractors and see who is safe and who isn't. Your insurance company won't be there to check them, but when they cut the check for sombody hurt, that will be the end of pulling.
