Tires again
Rick(MN)
10-06-2003 19:57:30
Priced tires for my Super M (14.9-38). $285.00 for Firestones, $255.00 for Titans. Also have a 10 year old set of Firestones on my Super MD, 80% tread. Is my best bet to move the used Firestones from the Super MD to the Super M for pulling and put the new ones on the Super MD? Your opinions please....sorry about the redundant questions. Thanks, Rick
770
10-07-2003 16:20:43
 Re: Tires again in reply to Rick(MN), 10-06-2003 19:57:30
Rick, this is strictly opinion, so take with a grain of salt.... A few years back, I took off a wore set of 15.5 tires on my ollie puller and replaced them with a set of new titan 15.5. The next two pulls I went to I spun out very early and when I pulled away I looked at my "groove". The bars wrer rolling on the tires. I took them off and put a used set of, believe it or not, safemarks. The next pull I got a first and a second. Worn, hard tires I think are the only way to go. Remember, just my OPINION...Good Luck.770
Eric
10-07-2003 21:43:25
 Re: Re: Tires again in reply to 770, 10-07-2003 16:20:43
I agree, one of my best set of pulling tires is an old set of safemarks.
Eric
10-06-2003 21:16:01
The older tires will in most cases be better for pulling. As tires get older they tend to get a little harder. Tall treads on new tires will curl under a heavy pull and they dig up a lot of loose dirt to drag the pan over. Try them both and decide for yourself.
Dale13
10-06-2003 20:48:13
I think the Titans are as good if not better than the Firestone's for all uses,pulling,farming etc.My experience is with the 14.9 38 on a Super M. My use is light farming and pulling.Never regret buying them.
