Massey Harris Pullin'
Jonathan
10-06-2003 18:30:05
I have a Massey Harris pulling tractor and I can not for the life of me get that thing glued to the ground. I have worked on the motor a lot and do not have any problems with the ponys. I have tryed moving the drawbar, transforing wieght from the frot the back, adding fluid and weight. If there is anyone that knows of any tricks please Email me.
P.S. I am pulling in the 4500LB class and I am at my weight limit.
slowsmoke
10-08-2003 15:25:24
 Re: Massey Harris Pullin' in reply to Jonathan, 10-06-2003 18:30:05
what size tires/ how much air pressure/how far back is the hitch?
razorback
10-07-2003 19:44:36
i too pull a massey, my latest thing to do b4 pull is to buy a case of elmers glue smire it on tires does ok for the first couple pulls then its gone to.
Jonathan
10-07-2003 18:28:31
I have pulled in second and did well. The club I am in only allows use to pull in first. I have a set of 14.9x38 Goodrich with about 65% tread.
FB
10-07-2003 12:33:49
Pull her in 2nd, what tires are you running?
andy
10-07-2003 09:20:15
I had a 44 pulled it in the 5000lb class, just spun out aoo the time, went to 6000 and started winning
marlowe
10-06-2003 21:03:33
i pull a 44special and a buddy pulls a 44 we both have 14.9x38 and we have totaly differnt set ups. i have short draw bar him long. we pull in 6000 an 7000 and are always in the top three. we found that they pull better in heavy classes.mine is 5280 with no wt. so i load it down with a 90 to 10 ratio. we pull most of the time on black top but on sat. we did clay and we placed 1and2 [got me by one in.].tires i think are the most important thing . some tires just don't pull well and you just have to find a set that will we both have firestone 23deg. at about 60% but i just got a set of 15.5 for black top at 10% will give them a try in the spring after i cure them
Flyin Farmall
10-07-2003 19:42:46
 Re: Re: Massey Harris Pullin' in reply to marlowe, 10-06-2003 21:03:33
Marlowe,Are you coming to Symco this Sat.??
marlowe
10-08-2003 17:31:24
 Re: Re: Re: Massey Harris Pullin' in reply to Flyin Farmall, 10-07-2003 19:42:46
if it don't rain. i'am going to call to night on thr rules
marlowe
10-08-2003 17:34:22
 Re: Re: Re: Re: Massey Harris Pullin' in reply to marlowe, 10-08-2003 17:31:24
no one home will try latter
a puller
10-06-2003 19:12:24
if there is no limit on tire size, get some 18.4 38" firestone tires and take it to a good hard track. Run 11 psi in the tires and let'er rip.
Family Tradition
10-07-2003 09:05:08
 Re: Re: Massey Harris Pullin' in reply to a puller, 10-06-2003 19:12:24
weigh it down.....every massey i have ever seen pull, pulled better in heavier classes.....your tires are probably floating out in that light of a class
