boring a JD A block
JD puller
10-06-2003 14:40:40
how big can I bore my unstyled A jd block with out having to put sleeves in it? I have been told that 5.875 is about the max but I think its to thin. let me know what all of you think.
Jonathan
10-07-2003 18:25:39
 Re: boring a JD A block in reply to JD puller, 10-06-2003 14:40:40
Just a little tip while you have the jug off. Shave the block about .0125 DO NOT SHAVE THE HEAD. It will not gain you anything TRUST ME!
I have done it and a buddy off mine shaved the block-----BIG DIFFERENCE!
Email me back for more tricks on a JD.
lynn
10-07-2003 17:15:49
JD puller..have 5.875 in my unstyled a and have run for 7 years and no problem..70 pistons work very well in my opinion..you have to leave the top of the cylinder unbored..about 3/4 to 1 inch so you have to load the pistons from the rear..helped a friend of mine put in cat pistons in a stlyed a last winter and they also worked..with 8 inch stroke in it he run a jerrys head to get the compession up as the pistons are short from the wrist pin to top and don't want to run ring into the spark plug hole..lynn
jons
10-24-2003 21:02:48
 Re: Re: boring a JD A block in reply to lynn, 10-07-2003 17:15:49
question for lynn.
what year do you have that you put the 70 pistons in? were the pistons for a gas or diesel 70?
thanks jon
a puller
10-06-2003 19:14:15
from what I have heard, most people go to 5.75 and use a cat...I think d7 piston or something like that.....ask "lynn"...he has this setup.
rusty
10-06-2003 17:11:26
You can bore it that size if you have the right cast block, the one w/ 2 circles on top of the block (ie old casting marks) have thick enough sleeves to go 5 7/8.
