Re:electric governor
eddie
03-24-2001 20:22:03
I doubt if it has an electric governor. Murphy sure as heck ain't smart enough to make it work nor is the rest of his group.
G Taylor
03-24-2001 23:23:50
 Re: Re:electric governor in reply to eddie, 03-24-2001 20:22:03
Could do it with off the shelf parts. Install a stepping motor attached to the fuel rack or carb throttle shaft & control via an onboard PLC. Install a position sensor on the throttle & rack or carb shaft. Installed a pulse generator on the crank &/or both rear rear axles to measure rpm. Work up the software with a proportional control with some integer calculations on your laptop. Likely wouldn't need the derivitive function. Could even monitor for mis-fire, O2 ratios,exhaust temps,oil/water temp, oil pressure, clutch slip, tilt change to prevent or limit wheelies and build in auto shut down protection.
Goldsburg
03-25-2001 06:26:11
 Re: Re: Re:electric governor in reply to G Taylor , 03-24-2001 23:23:50
G Taylor -
I think that your right on the money EXCEPT for the stepper motor part! I would think that a DC linear actuator would provide much finer control than the stepper. Something to ponder...
Regards,
Goldsburg
observer
03-24-2001 22:22:40
You got that right
