Harrison,AR pull OCT. 10th11th
Out Of Town Pul
10-04-2003 17:31:09
What are the Tire size and RPM limits, if any for the different divisions and classes? Are so called road worn tire allowed like USAP allows? Thank You, DW
Mr Animal
10-04-2003 18:13:45
 Re: Harrison,AR pull OCT. 10th11th in reply to Out Of Town Puller, 10-04-2003 17:31:09
Yes street run tires are ok. Cut tires on open class only. We do not push a tire size rule as long as you are with in reason. Draw bar height is 20" max. Open class must have kill swith and wheelie bars. Thanks for your interest and hope to see ya at Harrison,AR pull. ANIMAL
More Information Please
10-04-2003 21:38:37
 Re: Re: Harrison,AR pull OCT. 10th11th in reply to Mr Animal, 10-04-2003 18:13:45
What is your RPM limits? Is it wide open? Do you check RPM? Do you run a speed limit? Is 18.4-38 a reasonble size tire in a 4000# antique or open classes? Does your association have a set of rules on the net? Need to know before I travel 3 states. Thank You
Mr Animal
10-05-2003 14:19:08
 Re: Re: Re: Harrison,AR pull OCT. 10th11th in reply to More Information Please, 10-04-2003 21:38:37
The pull is being run under the Harrison,AR club rules. There will be no rpm's checked. The 18.4-38 tires can pull in the open class only. The speed limits will be 4 mph in all classes execpt open witch will be 12 mph. The classes being pulled will be farm stock, antique, classic, and open. If you have any more questions let me know or call Ronald Johnson at 417-256-9588. Thanks ANIMAL
RAZORBACK
10-05-2003 15:00:54
 Re: Re: Re: Re: Harrison,AR pull OCT. 10th11th in reply to Mr Animal, 10-05-2003 14:19:08
ALL THIS 18-38 TALK IN 4000, IS VERYYYY SCAREDIE
