front end
Denny
10-03-2003 08:51:44
looking for 460 or 560 front end [lower ped] to bolt on my M.
Ohio M Puller
10-05-2003 18:27:14
 Re: front end in reply to Denny , 10-03-2003 08:51:44
We make light weight frontends for H-450's. Come with 5 bolt hubs as well can set you up with 4" - 12" three rib tires to match. These will as well drop the nose of your tractor down to help in light classes when you need some nose weight. They look really good and unlike Denny's Carb Shop these won't break or bow. I have been running the same one for 3 years now and have had NO PROBLEMS. If interested contact me the email is a good way to reach me.
Ohio M Puller
Donnie
10-04-2003 07:26:56
If you want to lose a little more wieght and a shorter stance, get a front end off of a 656 Farmall. I have both and the 656 is about 20pds lighter and about an 1" shorter than a 460 or 560.
If you compare them you'll see the difference.
Matt
10-04-2003 18:32:52
 Re: Re: front end in reply to Donnie , 10-04-2003 07:26:56
What front end would fit on a IH 300, that would lose weight and lower the stance? Thanks.
randy hall
10-03-2003 10:54:56
i have one that i would sell complete with wheels and tires. email me at [email protected]
ChadS
10-03-2003 11:15:43
 Re: Re: front end in reply to randy hall, 10-03-2003 10:54:56
How much weight difference VS a stock pedistal, with pressed steel wheels?? Any info would be great. ChadS
