need help with a G mm for pulling
Mike
10-02-2003 18:45:48
Hi i am new to mm and need some help I want to make some more hp with out going in to the motor to deep I have new rings and just resealed the motor it is on lpg will run 16.9 34 on 16 in rims I have been told you can avance the cam but have not seen this done nor been told how? is there a better lpg car and regulator than the factory one what about milling the heads will this help. motor is bored over 0.030 Thanks Mike
Andy
10-02-2003 19:42:06
 Re: need help with a G mm for pulling in reply to Mike, 10-02-2003 18:45:48
I would find a set of 18.4X34 tires. I wouldn't mill the heads but get a higher compresson head like a 4213,(not to hard to find if you advertise on this or the MM page.) Call matt at motec 765-963-6628 He sells new LP equip and can answer your cam questions.
Jerry
10-03-2003 12:10:59
 Re: Re: need help with a G mm for pulling in reply to Andy, 10-02-2003 19:42:06
I pull with one also. I have 16.9 x 34 tires with about 5/8 tread in the center sharpened front and rear. Our club limints the tire size to 15.5 but because the 16.9's are replacements for 14 x 34 they overlook it. How much do you weigh. I pull 6000, 6500, 6700 Could go heavier but I don't like to sling a lot of weight. Mine is gas and I believe the propanes already have higher compression heads. You should have enough power but getting it to the ground is another thing. They have heavy front ends but its amazing how quick the front come up if a short chain is used.
Mike
10-03-2003 18:05:18
 Re: Re: Re: need help with a G mm for pulling in reply to Jerry, 10-03-2003 12:10:59
Not sure of the weight it is stock though no pto or hyd but has the heavy cast front 18 wheels I had a gb that i played with it pulled better in second gear than first but i was told the gtb like mine is a faster first gear now? just want to play and have fun but want to beat some jd and massey and a case la what can i do to motor to make more hp for under $1000 Mike
Jerry
10-04-2003 16:51:12
 Re: Re: Re: Re: need help with a G mm for pulling in reply to Mike, 10-03-2003 18:05:18
Cam, Carb. & Governor. It will help to have more RPM. Grind some off the weights in the Governor. You should use a gram scale when you do this to get both the same. I have not done this to mine but some on this fourm suggest moving the cam one tooth. I didn't pay attention as to which direction. Polish the ports in the manifold. Machine the ports larger in the heads. (Be carefull with that as you can ruin the head real easy if you get into the water). Remove the valve seats and machine the seat angles on the head and use larger valves. Use higher compression heads or shave some from your current ones. (Be carefull as these babys have a 4.62 inch bore and 6 inch stroke.) your rod and main bearing should be upto snuff or increased compression could ruin your motor. E-Mail me but make above id as I don't open the ones that I don't reconize.
