Tunica rules from last year:
Spotter
10-02-2003 13:26:33
These were rules in 2002. Won't be any significant changes...Spotter
SOUTHERN NATIONAL RULES
TUNICA, MISSISSIPPI
Mean Green Pulling Team and Fitzgerald�s Casino
Farm Stock II Classes
Pre-1960 Tractors with stock engine... No cut tires... 18.4 X 36 Maximum size... Hang on weights permitted... 10% over stock RPM allowed... Wheelie bars are mandatory... 1st. Gear only. 4mph maximum.
4 MPH & 8 MPH Classes (modified)
Pre-1960 Tractors with internal engine modifications...Spacer plates, girdles, power blocks, 12 port heads...800 heads and jugs are allowed... All parts must be on tractor origin...18.4 X 38 max. tire size...any cut, any rim width...no duals...Weights: 11' from center of rear axle to furthest point of front weights...Rear weights must not extend beyond rear tires...20% over stock RPM...Any gear, 4 MPH Max and 8 MPH Max...20" draw bar height, 18" back from rear axle...Wheelie bars & breakaway switches are mandatory...No alcohol, no nitrous, no turbos, no blowers.
No Speed Limit Classes
Same as above except 30% over stock RPM is allowed.
Speed limits begin when any part of a tractor passes the orange cone at � track. Tractors with side shields may be inspected prior to pull.....If a protest is made, it must be made before the end of the class. Protestors tractor will be examined first. Then and only then will the protested tractor be checked.
PULLING ORDER
(Only 3 pulls per tractor for 2 days)
FRIDAY SATURDAY
Farm Stock II Modified Modified Modified
(Green Sled) (White Sled) (Green Sled) (White Sled)
4500# 4 mph 6200# No limit JD King of the Hill All other King of the Hill
5500# 4 mph 7200# No limit 3500# 4 mph 6500# 8 mph
6500# 4 mph 7500# 4 mph 3500# 8 mph 6500# 4 mph
7500# 4 mph 7500# 8 mph 4200# No limit 5500# No limit
10,000# 4 mph 4500# 4 mph 5200# No limit
4500# 8 mph
5500# 8 mph
Have fun and keep in mind this is not a political event or debate!!
red rooster
10-07-2003 15:48:40
 Re: Tunica rules from last year: in reply to Spotter, 10-02-2003 13:26:33
no turbos why are you scared
Lamont
10-02-2003 20:01:08
Who do we contact for official rules for 2003? We need a professional opinion on the 930 CASE. Went to order a part and noticed the listing said "1959-1969 with 401 diesel." Is it allowed? This is the second published piece of literature that I've seen that shows 1959 for the 930. The parts section here on YT also shows 1959. Just wanting to join the fun.
Love from Aunt Esther, Rollo, Shady Grady and Pops,
Lamont
Slick Skillet
10-03-2003 04:36:16
 Re: Re: Tunica rules from last year: in reply to Lamont, 10-02-2003 20:01:08
Get hold of Wide Front Super M Puller,he can tell you.(Hayne Matthews I think).He has some postings on down the page.SS
Eddie Haskell
10-02-2003 17:15:10
Hey Spotter, that is 18.4x38 in the farm stock!!!
Thank you Mrs. Cleaver.
E.H.
Krouthead
10-02-2003 16:30:32
I cant wait!!I even bought a 50lb sack of FLOUR to roll that FAT LADY in and I dont have to tell you the next part,just look for the spot...ter!
The price of the Deutz scrap metal will extremely high in mid DEC!
Outa Hand
Krout
