looking for ways to lighten up Farmall H
puller
09-30-2003 14:42:57
aluminum trans covers any Ideas will help thank you!
Doug in OR
09-30-2003 15:37:37
 Re: looking for ways to lighten up Farmall H in reply to puller , 09-30-2003 14:42:57
Remove hydraulic pump. Remove pto shaft. Change wheels to stamped wheels. Remove belt pully if you have one. Remove all unneccesary steel.
From my own observations, you'll do better with it heavier. It's a matter of putting the weight in the right places and getting the proper drawbar height and length.
ChadS
10-01-2003 12:43:04
 Re: Re: looking for ways to lighten up Farmall H in reply to Doug in OR, 09-30-2003 15:37:37
Use W4 rear axles and housings. Probably 200lbs difference, A light weight front pedistal. Axle plates instead of hubs, Aluminum steering shafts, clutch, brake pedal shafts. Use a fiberglass fuel tank, aluminum weight bars, etc etc, ChadS
puller
10-01-2003 09:48:21
I have done all of that I'd like to get it down to the 3000lb class.
Farmall Boy
10-01-2003 13:36:57
 Re: Re: Re: looking for ways to lighten up Farmall in reply to puller, 10-01-2003 09:48:21
If your realy serious you need to build yourself a wide front end with rack and pinion steering..... . then you can remove that whole front piece if you attach the front end to the frame rails
