Mez25
09-28-2003 20:52:44
Thansks to TimC, he told me to lay out the specs of my H for some help. When i bought the tractor, the guy had a machine shop (didn't have the greatest reutation) and he said that he had done some work to it. It was weather beaten pretty bad, so i put new rear tires on the tractor and rims (they were loaded and rusted out). I replaced the spark plugs, rotary cap, battry &(cables), changed the oil, replaced some grease fittings, replaced muffler with straight pipe, flushed the radiator and gas tank, and installed a K&N Filter (bypassing the oil bath). I built my hitch and some weight brackets and pulled today. I also removed the governor casing plate and wired the governor spring together to increase my rpms and eliminate the play in the spring. I ran a 110 octane (leaded) fuel and finished slightly under average. The tractor is not restored yet, it was restored 2.5 years ago and the paint is slightly faded, but it is a nice tractor. It has 60 lbs oil compression and runs smooth. But as i said in my (Need Help) posting, i ran out of power. Yes many of the guys that i am pulling against are running "Hot" tractors and have thousands in the engine. I am pulling next weekend at the same place and would like to finish just behind some of these tractors. It's frustrating because, I enjoy pulling tractors, but i am highly competitive from my athletic days and i am afraid i will lose interest. I am asking you guys for some simple tips or some possible solutions to my problems that maybe i could turn some heads next week. I have used several of your tips already and they worked excellent. I don't epect to beat some of these guys that have thousands in their tractors, but if i could beat the guys that are stock and just crawl up behin these "hot" tractors i would be satisfied. If you could help i would appreciate it.
