M pulling tractor
Keith
09-28-2003 09:11:45
Ihave a 1945 M and I want more power for the farmers and farm stock classes. I pull in the 4500 and 5000 pound classes. I am pulling the engine this winter and going through it. I was wanting so ideas for bore and stroke and other mods I can do to do real real good in these classes. We have our own machine shop so will be doing work ourselves. Any help would be great.
Ohio M Puller
09-28-2003 15:40:03
 Re: M pulling tractor in reply to Keith, 09-28-2003 09:11:45
Go to the archives of this forum and look up " Free Advise " there is a great way to build a strong reliable motor that will give you a nice edge over your stock pullers.
Ohio M Puller
Farmaller
09-29-2003 17:13:07
 Re: Re: M pulling tractor in reply to Ohio M Puller, 09-28-2003 15:40:03
Question, if you turn the crank down and use stock rods what do you use for rod bearings?
Ohio M Puller
09-30-2003 04:02:03
 Re: Re: Re: M pulling tractor in reply to Farmaller, 09-29-2003 17:13:07
Use the stock rods, the journals will clear inside the block at that strock.
Ohio M Puller
FB
09-28-2003 09:41:11
whats the mph rule?
