Pulling Hitch
Mez25
09-26-2003 12:50:19
As you know i have a Farmall H, has anyone tried replacing the factory sabilizing arms with turn buckles, similar to those on a 3-point hitch. It may help me on adjusting my hitch to 18inches after adding weight. Just lemme know some pros's and con's. Thanks
Ohio M Puller
09-26-2003 13:04:44
 Re: Pulling Hitch in reply to Mez25, 09-26-2003 12:50:19
Seen many stock pullers do that and they seem to work well for them however the only problem I see is how can you be 100% sure that each turn buckle is at the EXACT same distance? Just always been a concern of mine on the way pullers set them up. If you are allowed by club rules pull the PTO out and cover the hole with a piece of 1/2" steal and weld a piece (1/2") on the bottom straight out. Them drill a 7/7" hole directly above your stock drawbar. Cut your drawbar off 2" past that marking and drill another 7/8" hole through the drawbar. Then place your hitch ontop of the drabar with its 7/8" hole init and us a piece of 3/4" all thread. Put a nut on the bottom of the drawbar and top of the hitch to hold them together and in place as well as one nut under the flat plate at the PTO cover and one on top of that plate, the two nuts are what you will use to raise and lower your hitch. All you will need is one 1 1/8" open end wrench to adjust your hitch height. Very easy to make and VERY LIGHT WEIGHT. P.S. I advise ou jusit the flat plate to the PTO cover plate for straigth. I have been running this setup for 3 years and have had no problems with it. Use this advice if you like good luck anyway and keep wondering why your tractor keeps pulling to one side or the other cause your hitch isn't level.
Ohio M Puller
Sleddog
09-26-2003 13:01:18
Category I top links are great for adjusting the drawbar height.
