question for SLEDDOG
danm
09-25-2003 08:01:35
Re: M govenor tweaking
Change the spring to a cot spring from your local hardware store.
what's a cot spring?
sleddog
09-25-2003 09:14:20
 Re: question for SLEDDOG in reply to danm, 09-25-2003 08:01:35
A cot spring is used to hold the flat springs in the frame in military bunks (old??). Actually it is of the same diameter and tensile strengty as the original governor spring. The difference is that it is shorter and will provide more resistance to the governor flyweights. It has the advantage of increased RPM without pulling the spring ends off. (ex. wiring the spring short.) Thak a governor spring to the hardware store and compare.
