Shaving Tires
Mez25
09-24-2003 11:08:36
As i mentioned to you guys earlier i am pulling one of my H's this weekend for the first time. I just put brand new rubber on it and am not sure if i should shave my tires, and if so how much and to what degree. I have heard several different methods and theories from the locals, but i have seen some impressive tractors that have not shaved tires at all, also vice versa there were some with shaved tires. Let me know! Thanks.
LJ
09-24-2003 18:06:33
 Re: Shaving Tires in reply to Mez25, 09-24-2003 11:08:36
dont cut brand new tires,there too soft,it doesent help any!
Allis puller
09-25-2003 18:25:18
 Re: Re: Shaving Tires in reply to LJ, 09-24-2003 18:06:33
LJ is right, new tires give to much. In order to make the tire hard I have found that leaving them in the sun and getting them real hot - then hose them down with water helps get the oils out of them. I have also heard burying them in manure helps but never wanted to put my new tires in sh*$. Most antique pulls don't allow cut tires and most antique pullers will pick up on them right away.
Ohio M Puller
09-24-2003 12:20:06
The best thing to do is chain off the front end your tractor to something heavy that isn't going to move. Then get yourself some bleach and spinn the tires in REVEARSE for a while. Dump the bleach on the cement that you are spinning the tires on to keep them from getting to hot and making soft spots on the top of the lug. This will give your tires that road worn look and help with bitting into the track. Make sure you runn the tractor up and down the gravel road or lane to edge them up and you will have no problems. P.S. Moke sure the tire pressure is the same in each tire before doing this.
Ohio M Puller
Farmall Boy
09-24-2003 15:16:10
 Re: Re: Shaving Tires in reply to Ohio M Puller, 09-24-2003 12:20:06
I would just drive it up and down the road till u get all of the little mold marks off.....i have done this and with my new 14.9's beat most road worn tires
JD
09-25-2003 11:26:52
 Re: Re: Re: Shaving Tires in reply to Farmall Boy, 09-24-2003 15:16:10
Farmall Boy, what about the John Deere A that consistantly gives you a spanking with 15.5*38's that are ROAD WORN??
Farmall Boy
09-25-2003 12:26:56
 Re: Re: Re: Re: Shaving Tires in reply to JD, 09-25-2003 11:26:52
Constantly????? check you're records and come back
JD
09-26-2003 15:46:39
 Re: Re: Re: Re: Re: Shaving Tires in reply to Farmall Boy, 09-25-2003 12:26:56
FB, if you're the one I'm thinking about, I think you need to at least get a driver's license before you start telling anyone else how to drive!! HA HA HA HA
FB
09-26-2003 17:39:35
 Re: Re: Re: Re: Re: Re: Shaving Tires in reply to JD, 09-26-2003 15:46:39
I have been driving tractors my whole life.....i
told no1 how to drive either, just ideas on how to
toughen tires.....if you can get into my class...I
PERSONALLY GUARNTEE U I WILL WHOOP THE GREEN OUTTA U
JD
09-26-2003 19:52:36
 Re: Re: Re: Re: Re: Re: Re: Shaving Tires in reply to FB, 09-26-2003 17:39:35
I'll be at the next pull. We'll see how road worn and new tires fair.
Ohio M Puller
09-25-2003 09:15:54
Well I am sure you have done so much more pulling than I ever will in my life and have all the answers so what was I thinking by giving of my advice (THAT WORKS). You must pull on some really bad tracks or just have more tractor than I could ever imagine!!! All I want to know is what hp are you running and what gear can you run in your classes that you pull. That will help me understand when it comes to what competition if any you are actually coming up against. Aswell as where you come up with your advice!
Ohio M Puller
FB
09-25-2003 12:25:21
 Re: Re: Re: Re: Shaving Tires in reply to Ohio M Puller, 09-25-2003 09:15:54
Never said my advice was better, just and easier solution and a way not to mess up new rubber
TimC
09-24-2003 11:28:36
Be sure the rules allow you for the class you are going to pull in. If you do need to cut then have it done by someone with a jig setup where every tread is cut identical.
