Oliver Deisel Puller
Mike
09-23-2003 18:01:40
I am looking to start pulling next year in the antique tractor pulls. I have been attending a few tractors pulls this year to try to get some pointers.When pulling with a gasoline tractor I have noticed that when the tractor begins breaking loose, the driver works with the brakes and throttles down some to get traction. The question I have is when running a deisel, and the tires break loose, you can use the brakes, but I have been told that a deisel needs to be run at high RPM's in order for the engine to run properly. If the engine boggs down, you can not get the rpm's back up fast enough to continue the pull. Is this true and is there any pointers for operating a deisel engine while pulling? I am new at this sport.
A.P.
09-24-2003 17:13:19
 Re: Oliver Deisel Puller in reply to Mike, 09-23-2003 18:01:40
It all depends on what kind of a combination you are putting together. The indirect injection Oliver diesels will lug well. They are not just a high speed engine. Some actually ride the brakes a bit to help warm the engine up. They run and pull better when they are well warmed.
A.P.
Mez25
09-23-2003 20:40:41
The key to any Antique diesel motor is high rpm's and you should still use your brakes. Unless you are pulling with an incredible amount of wheel speed, only then is the case you won't use your brakes. The key is to lightly engage your specific brake for a wheel that gets a little ahead of the other in order to achieve that positive balance.
720Deere
09-23-2003 18:37:32
You are probably talking about a detroit powered Oliver. The Detroit diesel is a two stroke engine and has it's powerband in the higher rpm's. Most naturally aspirated diesels will "lug down" and have alot of torque at low rpm. If it is indeed a Detroit diesel, don;t count on making much power below 1500 rpm!
A.P.
09-24-2003 17:16:25
 Re: Re: Oliver Deisel Puller in reply to 720Deere, 09-23-2003 18:37:32
Detroits do love RPM's that's for sure. But thay can pull down hard and still keep going if they are put together right.
A.P.
