Results Melbourne,AR
Mr Animal
09-22-2003 17:12:33
2500 Classic
1st-James Herrington-Lincoln,AR-41 Oliver 60-153.5
2nd-Gene Carr-Melbourne,AR-48' Oliver 60-151.3/4
3000 Classic
1st-James Harrington-Lincoln,AR-41 Oliver60-199.11
3500 Antique
1st-Richard Walker-Mtn Home,AR-39 Oliver70-297.3
3500 Classic
1st-Jim Bergren-Mtn Home,AR-38 Oliver70-289.5 1/2
2nd-Wally Doughty-Horseshoe Bend-48 Oliver70-244.2
3rd-Jim Bergren-Mtn Home-45 MM R-198.9 1/2
3500 Open
1st-Jimmy Norcross-Flippin,AR-57 Ford 960-272.6 2nd-Wally Doughty-Horseshoe Bend,AR-48Oliver70-144
4000 Antique
1st-Jim Bergren-Mtn Home,AR-39 Oliver70-200.11 3/4
4000 Classic
1st-Jim Householder-Mtn Home,AR-39 Oliver70-282.2
2nd-Jimmy Norcross-Flippin,AR-58 Ford 901-269.3 3rd-Virginia Mcspadden-Bradford,AR-FarmallH 206.6
4000 Modern
1st-Jim Norcross-Flippin,AR-58 Ford 901-268.3 3/4
2nd-David Watts-Zion,AR-58 Case 300-258.1 1/2
4000 Open
1st-Jimmy Norcross-Flippin,AR-57 Ford 901-203.11
2nd-Richard Walker-Mtn Home-38 MH 101-172.9 3/4
3rd-Jim Herrington-Lincoln,AR-57 Oliver77-157.2
4500 Antique
1st-Jim Berggren-Mtn Home,AR-39 Oliver70-108.10
2ne-Gene Carr-Melbourne,AR-30 HP Oliver10/27-82.2
4500 Classic
1st-Jim Householder-Mtn Home,AR-48 Lehr-151.8
2nd-Arwin Plymale-Viola,AR-46 MH 101-148.11 1/4
3rd-Jimmy Norcross-Flippin,AR-58 Ford 901-138.2
4500 Modern
1st-David Watts-Zion,AR-58 Case 300-178.9
2nd-JImmy Norcross-Flippin,AR-58 Ford 901-79.2
4500 Open
1st-Jimmy Norcross-GFlippin,AR-57 Ford 960-317.5 2nd-Jim Herrington-Lincoln,AR-57 Oliver77-290.9
3rd-Lindell Taylor-Bradford,AR-38 JD a-285.1
5000 Classic
1st-Arwin Plymale-Viola,AR-46 MH 101-269.301/2
2nd-Dalton McSpadden-Bradford,AR-50 Farmall-254.1
3rd-Jimmy Norcross-Flippin,AR-58 Ford 901-249.1
5000 Modern
1st-Jimmy Norcross-Flippin,AR- 58 Ford 901-290.5
2nd-David Watts-Zion,AR-58 Case 300-177.7
5000 Open 1st-Jimmy Norcross-Flippin,AR-57 Ford 960-330.9
2nd-Jim Herrington-Lincoln,AR-51 Oliver77-301.2
3rd-Lindell Taylor-Bradford,AR-38 JD A-249.2
5500 Classic
1st-Allen Strain-Clarkridge,AR-52Deutz ps50-186.0
2nd-Ronald Johnson-West Plains,MO-54 Farmall 177.0
3rd-Jimmy Norcross-Flippin,AR-58 Ford 901-175.1/4
5500 Modern
1st-Jimmy Norcross-Flippin,AR-58 Ford 901-183.1/4
2nd-David Watts-Zion,AR-58 Case 300-149.1/2
5500 Open
1st-Jimmy Norcross-Flippin,AR-57 Ford 906-239.5 2nd-Jim Herrington-Lincoln,AR-51 OLiver77-216.1/2
3rd=Sonny Daniels-Hernando,MS-48 Farmall M-215
6500 Classic
1st-Jim Brassfield-West Plains,MO-53 JD R-246.8
2nd-Allen Strain-Clarkridge,AR-52Deutz ps50-235.4
3rd-Jim Edens-Bradford,AR-55 MM GB-234.3 3/4
6500 Open
1st-Keith Edens-Bradford,AR-55 MM G6-314.9 3/4
2nd-Sonny Daniels-Hernando,MS-48 Farmall M-275.4
3rd-Richard Walker-Mtn Home-54 MM U-275.0
7500 Classic
1st-Jim Brassfield-West Plains,MO-53 JD R-265.3/4
2nd-Allen Strain-Clarkridge,AR-54Deutz ps65-253.11
3rd-Jim Edens-Bradford,AR-55 MM GB-232.2 3/4
7500 Open
1st-Keith Edens-Bradford,AR-59 MM G6-322.0
2nd-Ryan Shute-Bradford,AR-53 Farmall M-282.1
3rd-Joyce Taylor-Bradford,AR-38 JD G-279.4 3/4
8500 Classic
1st-Jim Householder-Mtn Home,AR-57 Oliver-319.9 2nd-Jeff Sanford-Bradford,AR-59 Case 960-316.4
3rd-Tim Sanford-Bradford,AR-59 Case 930-308.1 1/4
8500 Open
1st-Allen Strain-Clarckridge,AR-57Deutz8005-277.10
2nd-Richard Walker-Mtn Home,AR-58 MM GB-312.5 3/4
3rd-Jim Brassfeild-West Plain,MO-58 JD 820-290.7
9500 Classic
1st-Jeff Sanford-Bradford,AR-59 CAse 930-330.7 1/4
2nd-Jim Householder-Mtn Home,AR-57 Olivers99-330.3
3rd-Tim Sanford-Bradford,AR-59 Case 930-329.11 3/4
9500 Open
1st-Gene Bradley-Mtn Home,AR-58 MF 97-328.5 1/2
2nd-Jim Householder-Mtn Home,AR-57 Olivers99-326.2
3rd-Jim Brassfield-West Plains,MO-58 JD 820-311.9
10,000 Classic
1st-Gene Bradley-Mtn Home,AR-58 MF 97-198.9 1/2
2nd-Jeff Sanford-Bradford,AR-59 Case 930-197.5 1/4
3rd-Tim Sanford-Bradford,AR-59 Case 930-197.3 1/4
10,000 Open
1st-Gene Bradley-Mtn Home,AR-58 MF 97-193.10 3/4
2nd-Allen Strain-Clarkridge,AR-57 Deutz8005-186.5
10,000Plus Open
1st-Gene Bradley-Mtn Home,AR-58 MF 97-196.11 1/2
2nd-Allen Strain-Clarkridge,AR-57 Deutz8005-186.10
4WD Trucks
1stJames Walters-Melbourne,AR-01Dodge,Cummins194.4
2ndRandy Lovelace-Melbourne,AR-02Ford,PS-186.2
3rdRick Gillaspie-MelbourneAR-02Dodge,Cummins166.7
Not a chevy to be found. Thanks again to all for a great pull and a great group of people. It doesn't get any better than this you all. See ya at the next pull, Harrison,AR Fall Pull and Show, OCT, 10th&11th. God Bless to all. ANIAML
piston
09-22-2003 19:04:51
 Re: Results Melbourne,AR in reply to Mr Animal, 09-22-2003 17:12:33
animal soming about 8500 open doesnt look right in the results section, cant spell but i can add an subracts,
Mr Animal
09-23-2003 04:18:55
 Re: Re: Results Melbourne,AR in reply to piston, 09-22-2003 19:04:51
In the 8500 open Allen Strain should have been 321.3 1/2 on the repull as he was first out instead of 227.10. Sorry Even the Animal is part human. see ya. ANIMAL
Hillbilly Hooker
09-24-2003 20:18:35
 Re: Re: Re: Results Melbourne,AR in reply to Mr Animal, 09-23-2003 04:18:55
REPULL!!!!! ! I thought only the Black Whiner ooops I did it again, I mean the black widder team was the only ones to get a repull. Respectively yours Hillbilly Hooker
Hillbilly Hooker
09-22-2003 20:05:05
HMMMM! looks to me like the Kremlin actually got a Butt Whoppin. Just think how bad it would have been if you hadnt busted the hub. Also I noticed two-tone got a Butt whoppin from a 13yr old kid . Just stirring the $hit H.H.
Krouthead
09-23-2003 04:53:39
 Re: Re: Re: Results Melbourne,AR in reply to Hillbilly Hooker, 09-22-2003 20:05:05
I sure am glad I pulled 1st!I will not run out of pertrol again!
Next time I wont back off....I felt sorry for dad!
Krout
Mr Animal
09-23-2003 04:23:30
The Ford 901 and Ford 960 did not have a bad day either. I think two tone is feeding his tractors some high powered bean gas mixed in to the propane. That is what the other valve is for!!! ANIMAL
