will 14.9 by 38 work on 17 in wheels
Mike
09-21-2003 18:51:21
Thay have changed the rules where i pull and cant run 16.9 any more dont want top buy new rims can i run 14.9 on my 17 in rims would this be the best tire ot is a 15,5 a better choice. I am pulling a hevely modified H farmall with a cotton picker low gear set and in 3600 to 5600 pulls better at 4600 Thanks Mike
Don
09-22-2003 05:57:46
 Re: will 14.9 by 38 work on 17 in wheels in reply to Mike, 09-21-2003 18:51:21
As far as them mounting up, yes they will work. I have know guys that pull antique for the ITPA that use a 18" rims with 14.9 and 15.5 tires. Me I would rather use a 14.9 cause it is a little taller then the 15.5.
Krouthead
09-21-2003 19:18:10
I dont know about your club rules,but typically for stock and classic,you are required to run the wheel size that is for the tire(usually marked on tire)I am not sure but I think 14.9 is the same wheel as 15.5,which is 14 inch wheel and 15 for 16.9.I did not know the wheel for 16.9 but after a call to the ever helpful NATPA tech crew they had me on the right track.
Hope this helps,maybe.
Krout
