John Deere 720
Farm w/Junk
09-19-2003 13:21:26
Anyone here pull any 720 diesel tractors? What weight class are they in? Are they very competitve or not worth taking? It is a n/f with 15.5 38 tires. What gear or speed would be good? Thanks.
Matt
720Deere
09-22-2003 17:19:12
 Re: John Deere 720 in reply to Farm w/Junk, 09-19-2003 13:21:26
I pull a 720D anywhere from 8000 to 10500 lbs. Depending on the type of track, can usually pull in second gear up to around 10000. I don't think that I have ever seen a healthy one run out of power in low gear.
We run 16.9-38's and still seem to have plenty of power. Actually a little too much for the lighter classes. It seems to like to weigh at least 9000 lbs for a good pull. Run a super clean air intake system and find the right spot with the rack limiting screw, and you'll soon find out that 15.5's don't seem like that much tire!!
52 A Boy
09-19-2003 14:08:54
I pull a 730 Diesel, it is very competitive in 9600, 10600, and 11600, I havent taken past 11600 but i had plenty of power left. If it has the creeper in it you'll spin out before you ever power out, if not about 9600 is were you would start to lose power, but with those 15.5's the tire might be short enough to were you would still spin. With your setup you would be around 7600-8000#'s. Just take it and try it out, its all about having fun.
52 A Boy
Farm w/Junk
09-19-2003 14:50:51
 Re: Re: John Deere 720 in reply to 52 A Boy, 09-19-2003 14:08:54
Do you have your 730 weighed down with wheel weights? If so how many? The 4020 wheel weights fit dont they? Thanks.
Matt
52 A Boy
09-19-2003 15:03:11
 Re: Re: Re: John Deere 720 in reply to Farm w/Junk, 09-19-2003 14:50:51
Yes I have wheel weights on it i put 4 on each side and sometimes 5 on each side, then from there i hang suitcase weights on. Yes the 4020 weights will fit.
52 A Boy
