Weight brackets
MM R/Z
09-05-2001 14:29:59
Is it possible to put weight brackets on a Minneapolis R or a Z?? Any info would help, thanks~
Dale G
09-06-2001 07:25:24
 Re: weight brackets in reply to MM R/Z, 09-05-2001 14:29:59
I mounted a weight bracket on the front of my ZA by using the bolt holes on each side of the hand crank hole and then extended a bumper down to the spindle for stability. Good Luck!
H
09-05-2001 19:55:07
no
Shawn
09-05-2001 18:10:07
Hello,
Na, its just almost impossible to put them on that tractor.
Yes there is, if there is a will there is a way.
Havent you looked at any other tractors before, there are several pulling and all are different
pick your way and go metal happy
Shawn
