560 Puller
Farmall Daddy
09-15-2003 18:41:01
Was wondering what classes you guys would think a stock 560 would pull in. It weighs in at 7440. Has fluid in front and back tires. 15-5-38's with about 75-80% rubber. Fast hitch, and has the factory front bracket on it. No wheel weights. Torque works, and is set at 1850 rpm's. Thanks in advance!!
Farmall Daddy
Eric
09-15-2003 19:08:12
 Re: 560 Puller in reply to Farmall Daddy, 09-15-2003 18:41:01
Obviosly you could pull it in a 7500# class or weight it up to 8500#. There are a couple of 560s that I pull against that got them down to 6500# (no fluid in tires and a little stripping) and do pretty good. With a stock 560 you could pull div 2 and compete.
