propane injection
jim
09-14-2003 18:50:49
Where might i find a propane reugulator(solenoid) that i could regulate propane at about 2-4 psi? thanks
buickanddeere
09-15-2003 19:33:32
 Re: propane injection in reply to jim, 09-14-2003 18:50:49
A nitrous solenoid ,plumbing and jets work fine. Injecting liquid LP cools the intake mixture slightly making it denser. Most diesels can get lots of fuel, getting enough airflow is the problem.
TimC
09-15-2003 06:11:15
You might check out a message board for diesels like the power stroke or cummins. I would think you need to know how to get enough volume at 2 to 4 psi.
LW
09-15-2003 05:45:11
A torch regulator, for the solenoid a nitrous solenoid would work.
