Results for Batesville AR, pull
Mr Animal
09-14-2003 18:48:59
Thanks to all the pullers that made there way to Paragould, AR pull on Sat. The weather had the pull in question but we got the pull started at 4:30. The track was packed and the tractors were hooking hard and really pullin. We had 33 tractors and all had a good time untill the sky opened up with just six more pulls to go. Well here are the results.
2500
1st Larry Brannam 42' A/C B
2nd Miranda Boggs 56' A/C CA
2500 Open
1st Miranda Boggs 56' A/C CA
3500 Antiqe
1st Rodger Roseman 39' MM R Nearlyville,AR 3500 Classic
1st Jim Cox 50' Oliver 66 Nearville,AR
2nd Michael Tillman 51' A/C WD Bernie,MO
3rd Christopher Lindsy 50, Oliver 66 Farmington,MO
4500 Clssic
1st Lucus Tuner 51, M/H 44 Bradford,AR
2nd Joe Monday 51, JD B Pollard,AR
3rd Billy Jackson 45' Farmall Pollard,AR
4500 Open
1st David Stroud 55 Oliver 88 Farmington,MO
2nd Lindell Taylor 38 JD A Bradford,AR
5500 Classic
1st Christopher-Lindsey 49,Oliver 88 Farmington,MO
2nd Joe Monday-51' JD B Pollard,AR
3rd Michael Tillman-48 Case DC-Bernie,MO
5500 Open
1st Matt Stroud-55' Oliver 88 Farmington,MO
2nd Lindell Taylor-51 JD A Btradford,AR
3rd John Inman-58' Farmall 460 Popolar Bluff,MO
6500 Classic
1st-Allen Strain 52 Deutz PS 65 Clarkridge,AR
2nd-Joe Monday-51' JD B Pollard,AR
3rd-Lee Inman 58' JD 630 Pollard,MO
6500 Open 1st-Keith Edens 59' MM G6 Bradford,AR
2nd-Doug Deckard-59' IH 660 Piggett,AR
3rd-David Stroud 55 Oliver 88 Farmington,MO
7500 Classic
1st-Lee Inman 58' JD 630 Popolar Bluff,MO
2nd-Allnn Strain 52' Deutz PS 65 Clarkridge,AR
3rd-Jim Edens 55 MM G6 Bradford,AR
These are the results. Sorry about the rain. We will be in Melbourne,AR on Sat. the 20th for the county fair pull. The track at Melbourne ,AR is a good one and always draws a good batch of tractors. So come on to Melbourne, AR and get your pull on. Thanks again to all those that helped make the Paragould,AR pull happen. The "Tough Sleddin" team can't make the pulls with out you pullers. See you at the Melbourne,AR pull. If you need any info call Gene at 870-404-7167 or Randall at 870-346-5169. Also you may E-mail me at [email protected] Thanks, ANIMAL.
Results from Paragould Pu
09-15-2003 08:29:59
 Re: Results for Batesville AR, pull in reply to Mr Animal, 09-14-2003 18:48:59
Sorry some how the above named Basteville pull should read Paragould pull. ANIMAl
Hillbilly Hooker
09-16-2003 17:06:56
 Re: Re: Results for Batesville AR, pull in reply to Results from Paragould Pu, 09-15-2003 08:29:59
I warned you of the effects of that Jack Daniels. If you would try Canadian Blended it wont burn them cells so bad. ha ha see ya Saturday H.H. p.s. I think we are camping saturday night.
