oliver 310 help
Kevin
09-11-2003 20:14:05
I have a 310 oliver diesel that i pull. I run about 40 lbs of boost and i can't keep the head gasket sealed. Need to know where to have it o-ringed. any help would be apreciated
thank you
Answer
09-14-2003 16:57:48
 Re: oliver 310 help in reply to Kevin, 09-11-2003 20:14:05
What is your compression ratio with and with out the 40 PSI of boost. Here I think lies the problem.
TimC
09-12-2003 06:09:31
Any machine shop that has a boring bar can do it. You should probably find a machinst that does it for the race car guys. A 35 thou wire with 15 or less sticking out of the groove should do it. O-ringing is like anything else though. Everyone has their opinion on how it should be done.
