hardblock in blocks???
Jim
09-10-2003 20:19:17
does it work???
deadeye
09-14-2003 08:34:13
 Re: hardblock in blocks??? in reply to Jim, 09-10-2003 20:19:17
Yes it works. If the block has it in there and you want it out, better throw that block away and start over with one that does not have anything in it.-----deadeye
TimC
09-11-2003 19:37:03
It works very well for what it was designed. Be sure to check all the cyls with a dial bore gauge. It may need to be re-honed to get the bores round and no taper. You may also need a little more clearance in the bore and just a little more ring end gap. They get hot and you need to run an electric wp and fan to get her cooled back down. You also need to bore and tap a hole in the back of the head. All this is if you fill it to the top.
MAD DUC
09-11-2003 15:11:14
What I want to know is how do you remove it from a block?? I bought a power-block that the previous owner used it to seal a leaky liner, but it did not stop the leak. So I want to get all of this hard block out and fix the leak. Plus this tractor will also be "used" in the field and I'm concerned with it overheating due to lack of coolant flow. So far have been chipping it out with a hammer and different punches. Is there a better(easier)way??
Jason
09-11-2003 12:40:39
What is it that all you are talking about? Hard Block??
LW
09-11-2003 19:58:13
 Re: Re: hardblock in blocks??? in reply to Jason, 09-11-2003 12:40:39
Its tile grout with some iron powder mixed in it, I have used tile grout with the same results but alot cheaper.
H
09-11-2003 13:11:38
It's almost like a cement, that's added to the water passages to help slow down the cylinder
deflection.
880 puller
09-11-2003 06:07:28
yes, we like it very well
GUS
09-11-2003 08:13:04
 Re: Re: hardblock in blocks??? in reply to 880 puller, 09-11-2003 06:07:28
WILL IT WORK IN A JD G BLOCK???
JDGnut
09-11-2003 08:03:01
Just curious... How far do you fill the block??? JDGnut
