Lightening up a JD B
JohnDeere2Cylinder
09-10-2003 13:34:19
Thanks in advance. I have a pure stock 1949 John Deere B that I am trying to lighten up for pulling. I have taken off the seat and battery case, made a lightweight bracket to support one of those "hang-ass" seats with the holes in, changed to a smaller 12v battery, changed to an alternator, replaced to a flat back but kept the PTO for a dyno, changed the hitch to a shorter hitch with a pulling eye, changed to pressed steel wheels with 14" wide rims and 13.6 x 38 tires, changed the roll-o-matic to the simple straight front end, removed the shutters, removed the oil bath air cleaner and replaced with an air filter. I now weight about 3600 with me on it (about 200# allowance for driver). What else can I do to lighten it up by 100# so I can enter a 3500# class? Thanks.
JD B Puller
09-12-2003 10:40:59
 Re: Lightening up a JD B in reply to JohnDeere2Cylinder, 09-10-2003 13:34:19
If your are serious, you can get a late style B below 3,000#.
JohnDeere2Cylinder
09-12-2003 11:47:30
 Re: Re: Lightening up a JD B in reply to JD B Puller, 09-12-2003 10:40:59
I am serious. Last night I installed some 12" front wheels to replace the 16" originals. They allow this in the pure stock classes in our neighborhood. What next?
2 Cylinder
09-11-2003 05:19:02
You could remove your generator assembly, and recharge battery between pulls. That will lose about 30-40 lbs, which is what I did. I have seen some of the pullers cut out the centers of the pressed wheels to lose weight also, also find a light driver for the light class. My 2 cents.
Wendel
09-10-2003 16:20:38
Sounds like all this tractor is going to be used for is pulling so you can remove rear hubs and weld axle plates for the 9 bolt press steel wheels
