FARMALL LP HEAD
Darin S
09-10-2003 07:32:27
What makes an LP head more desireable the a gas head? I'm working on a 350 Farmall for pulling and need a head. I found a LP head but it's not cheap. Thanks
Red Rider
09-10-2003 20:41:50
 Re: FARMALL LP HEAD in reply to Darin S, 09-10-2003 07:32:27
A 350 gas head will make 7.01 to 1 compression with flat top pistons. A 350 Propane head will make 8.75 to 1 with flat top pistons.
Chads
09-10-2003 12:28:28
You could use the SH-350 gas head, yes the lp head is good, but you could close to the same flow and compression chanber with the gas head. A little port and polish work, and some milling would have to be done. It is a stock engine? what kind of pistons? M&WS? Chads
WILDMAN
09-10-2003 10:32:25
MORE COMPRESSON BETTER FLOW
